Hi,
I am fitting CBR600 stick coils and wonder if the polarity matters when wiring the CBR connectors on to Firestorm.
Cheers,
Stewart.
CBR600 Stick Coil - does polarity matter?
Re: CBR600 Stick Coil - does polarity matter?
Yes.
The spark should jump from the centre electrode out to the ground terminal.
If you put voltage to ground, then expect a spark to occur, you may have to wait a while.
Just follow the colour coding from the donor bike's wiring diagram.
Yes black with white trace is the ground, and common to both coils. The other wire (colored not black) is the hot one..
Id also mention I make custom plug and play cables for this MOD, but you UK guys are cheap as chips
So I figured Id just tell you the answer for free
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
