Not a cheap option at about $16 per set
And a huge stumbling block for common use for most here, it needs a $300 OEM HDT-48-00 crimp tool or a $400 DMC AF8 M22520/1-01 crimp tool frame and a $130 positioner turret for this specific Milspec terminal pin and socket used in the Deutsch DTP body
And of course in the DTP high amp series , only 2 and 4 place body's are available. But overall size on the 4p one is still ok for a VTR use, so thats what Im going with.
A possible solution would be to have connector pig tails made and user install them via a uber high quality Mil / AV spec crimp splice..but now your back to a pricey crimp tool..
Or a pig tail the end user solders on and protects with dual wall adhesive lined heat shrink tube like Raychem dr25 ...the down side, and the reason I went to plug and play cables for my RR kits.. The kit, the install the final product would then relies on a perfect soldiered joint.. Something I rarely see in DIY stuff posted online.
I have the connector kits and crimp tool frame on hand now, the new DMC turret is set to be delivered today ...
Some quick crimps on my chosen test bed bike (lol mine) and some wire pull tests and we will see what we see
