QD X2 and fuel pump and X 2 tee piece, sevenoaks, £30 posted
Moderator: VTRDark
Fed up with fuel leaks when you take the tank off? Here's the full kit. Splice the two qd's into the fuel lines between the tap and the carbs.
For £30 posted, you can use the two brass Tee's to make a single line through the Honda low pressure fuel pump, (not pictured, its at the back of the garage behind three bikes) and wire it to a switched live.
You do not have the required permissions to view the files attached to this post.
