Koso heated grips
Nosepicker
Koso heated grips
Post by Nosepicker »
I'm sure this has been done a thousand times before, but I would like to contribute a bit so here it goes - I think :confused :D
Quality wise Oxford has always been my choice when it came to heated grips, but I have never been to keen on the thermostat/controller unit.
So I'm gonna try these Koso's out. Please let me know if anyone here has experience - good or bad - with them.
Grips and control unit fitted - no screaming or use of hammers so far :D
Getting the wires sorted
Trying to place the fusebox an accesible place
Wire extensions sorted
All done - and they actually work. Might reward myself with a chilled beverage :beer:
Nosepicker
Re: Koso heated grips
TaxiDriver
Post by TaxiDriver »
That looks pretty slik………...
How much fatter than normal grips?
TaxiDriver
Is there an inline fuse with this system?
They look really neat!
Better than the Oxfords in my opinion. I like the way the controller is hidden in the loom and the switch is integrated into the grip.
I've just had a look at the specs and I see they come with an inline fuse, auto shut off much the same as the oxfords. If they last as well I think Oxford will have some competition the next time I need a pair :D
Nice job, well done :clap:
Nosepicker
tony.mon wrote: Fri Apr 03, 2020 9:15 pm How much fatter than normal grips?
They're about 5mm (diameter) on the chubby side compared to the ones I binned :D
