Front end refresh and Delete kit
TaxiDriver
Post by TaxiDriver »
Had a tidy up of the front end with resprayed legs,stainless bolts and pins and caliper mounting bolts nickel plated.....
Then fitted a rear brake reservoir delete kit,for something so simple,what a wombling faff,especially the clips..... :twisted:
Pentode
Re: Front end refresh and Delete kit
Post by Pentode »
That front end looks really good! I've not seen a reservoir delete kit before (very sheltered life..!), again, looks very tidy 👍
Insufferable halfwit.
mik_str
Post by mik_str »
Looking good!
There's a reasonably priced HRC kit available for the rear res.
Just remember to schedule an annual fluid change.
Looking good to me as well :thumbup:
tidy looking bike :thumbup:
jbf955i
Post by jbf955i »
Hi Taxi,
Forks look very good. What did you use?
Mine are a mess, as you can see on the picture. The rest isn't bad at all.
I just need to sort the forks out pal..
Jason
Sent from my SM-G960F using Tapatalk
TaxiDriver
Was put onto Simoniz satin spray by another member on here,3 or 4 coats and your good.
Rhughes945
Post by Rhughes945 »
jbf955i wrote: Sun Apr 19, 2020 3:23 pm Hi Taxi,
Jason
I did mine recently, stripped off what I could of the previous crap paint job and used some etching primer (2 or 3 coats should do) and then finish off with a decent paint.
I used simoniz 5 wheel paint.
https://www.reactiveparts.com/hrc-honda ... r-kit.html
Is this the delete kit used above?
Yes.
