Garage Door
Garage Door
It went bang!!!! The door has dropped, the cables are slack and it's a bugger to shift. So it will stay closed till the garage door man has been. Trouble is the bike is the wrong side!!!!!
Re: Garage Door
Richard wrote: Thu May 21, 2020 5:25 pm It went bang!!!! The door has dropped, the cables are slack and it's a bugger to shift. So it will stay closed till the garage door man has been. Trouble is the bike is the wrong side!!!!!
Been there done that... Sacked the up & over & had it replaced with doors...wernt cheap but me & next door adjoined garages had both done at same time so got a bit off...
These ones in white...
https://www.accessgaragedoors.com/side- ... age-doors/
Was just over grand tho.... 8O
Re: Garage Door
That’s not too bad. I’ve just replaced my up and over type door and it was about£800
Richard, they can just replace the cables. The kits used to be about £35 but that was 20 years ago when I did mine
Re: Garage Door
Had cables done a year or so back.
Not expensive. I tried buying the cables and doing it myself but there's a knack to it that I couldn't be bothered to work out, so got a blokey in.
Re: Garage Door
tony.mon wrote: Thu May 21, 2020 7:27 pm Had cables done a year or so back.
It's a bit more than a knack... You have to retension the spring.
When I worked at British Bakeries I was shown how to fix the bay doors. 72 of the fekers on bays for HGV's to back on to the loading bays.
The bloody drivers were always feking them up by leaving things in the way, as the doors came down they hit whatever was left there, door goes out of level, tension on one side goes out, cable comes off rollers...Stupid driver trys door again, cable wraps round roller...
So you had to unravel the cable & re tension the spring... Think of the one on your garage door & multiply by 25 in size... Lets just say it was a bit of a PITA...
Re: Garage Door
Garage up and over doors vary in different types of spring set-up's surprise surprise depending on which make door you have. Some cables are not too bad to replace if you know what you are doing, while others (as Mac says) are not that easy, and are really a two man job,
Re: Garage Door
Yep!
Mine was a piece of pi$$.
Just pull the cable out full and stick a screwdriver in the mech to stop it winding back. Feed it around the pulleys and hook it on the door.
Don’t know what you monkeys were doing but I just read the instructions
Re: Garage Door
Ohhhhhhh boys now now, no handbags please
Mines only a little old domestic up and over, not sure if the spring has gone or just the tension, but a man in a van cometh and all will be revealed..........let there be light!!!!
Re: Garage Door
As to instructions, I prefere looking at pictures 🤪
Re: Garage Door
Richard wrote: Thu May 21, 2020 10:39 pm Ohhhhhhh boys now now, no handbags please
I put spring when I meant cable in my post above, I have changed it now :wink:
Bikerbob
Re: Garage Door
Post by Bikerbob »
Its a job on my list. The frame has rotted ,and I can do that. Getting the door out and back again will be fun. Would get a man in but they are not interested in playing with old doors .just want supply new ,but not do the rest which involves windows etc. and pukka carpentry.
Re: Garage Door
The garage door man has come, and gone!!!
The door now works, although he spent sometime with a " Brummie screwdriver" fine tunning it 🤪
The actual tightening looked straightforward, but it's working and I and the bike can Escape!!
Pina Colada anyone hi 🥳
Re: Garage Door
Richard wrote: Fri May 29, 2020 4:10 pm The garage door man has come, and gone!!!
:thumbup: :clap:
Re: Garage Door
sounds like an open and shut case :thumbup:
Re: Garage Door
AMCQ46 wrote: Sat May 30, 2020 11:23 pm sounds like an open and shut case :thumbup:
Ohhhhhhhh 😁
Careful you don't cut yourself!!!!!😁😁
It even goes up, and down nicely now with little effort! Amazing how one gets used to poor performance...........the wife agrees 😗
