Are the R/R different on those models or should I replace with later version with cooling fins or are they dodgy too and go the R1 mod?
I will order manual ccts and replace if required.
Also in regards to changing cans I assume need to replace links pipe to fit slip on cans?
However I am undecided if I change or debaffle factory ones. They are around 40000 Yen or 280 ish pounds for a full header and mori or yoshi system here although used
Thanks for any advice
