Iβve just put an RCS on my old (1991) zx-10 in an effort to get this century braking , and combined with pads , braideds and calliper service it feels 100% better
While I had it loose I offered it up on the storms bars and the only issue I could see was the standard brembo reservoir and bracket clashed with the screen
Has anyone done it on here and was it with a different reservoir / bracket ??
I haven't fitted an RCS, but I have a Nissin radial calliper off a Suzuki on mine and also had to move the reservoir.
You can fit any reservoir and any length of hose and any shape of bracket, as long as the reservoir is above the master cylinder it will work as normal.
I just made a new bracket and was able to put the pot out of the way, go for it
iv a blade master on apex 3" riser bars and also had to move the res inbound on a bracket to clear the fairing, as Al said it doesnt matter how long the pipe is as long as its above the master even slightly..
AMCQ46 wrote: βSat Oct 31, 2020 9:42 am
Thanks will start looking at different brackets and reservoirs
fabiostar wrote: βSat Oct 31, 2020 10:30 am
Thanks
for the res bottle you can get loads of little rip off Brembo units that are tiny to give you more room.
Thanks
Good idea .... will look at those , with a custom bracket
I've got ZX14 radial brake and clutch masters (coz I get a bit OCD and they have to match ), I used the ladybird style res mounts from kurveygirl. They are long enough (actually too long), and you can bend and twist to get the desired shape.
Twitchy wrote: βWed Dec 09, 2020 10:13 pm
