Clicking noise
Mark465
Clicking noise
Post by Mark465 »
Hi all, I’ve got a beautiful’03 Firestorm with 20500 on the clock. When the engine is off and in neutral when I push it forward I get a click; but not when going backwards- any advise greatly appreciated
Re: Clicking noise
Greetings
To reduce sound of 'click' fit a loud exhaust can and wear earplugs :-) Seriously, most likely chain on link pipe...
Plus any pics of your new Storm beastie?
:this_thread_is_useless_without_pics:
Re: Clicking noise
Chain on link pipe is usually evident when wheeling backwards. Check wheel bearings, or an undoing sprocket nut touching the swingarm.
haynesjones66
Re: Clicking noise
Post by haynesjones66 »
ride it backwards
KevA
Re: Clicking noise
Post by KevA »
Brake pads loose in the Caliper maybe, See if you can move them up and down in the caliper by hand.
Over to you Peeps..
gilson
Re: Clicking noise
Post by gilson »
ACL? ;)
No bike (yet).
Re: Clicking noise
Could be the chain is adjusted too tight. :D
grumpyfrog
Re: Clicking noise
Post by grumpyfrog »
Is it a single click or repetitive.
If single try your headstock is tight enough.
Don't hassle me
I'll get there at some time
jchesshyre
Re: Clicking noise
Post by jchesshyre »
I find that at certain stages in the chain/sprocket life I get a clicking from the front sprocket as the chain passes round it, when wheeling the bike around, but it's not a problem - last chain and sprocket set I had finally needed changing after 33,000 miles and had made this noise sometimes during that life.
