Theoretically maximum RAM air pressure explaine
VT1000r
Post by VT1000r »
Hello, I posted something about RAM air exactly 364 days ago it just so happened to be my last post until now. I've done a lot of research on RAM air and studying fluid dynamics quite a bit in general like venturi effect and aerodynamic drag for subsonic vehicles, very interesting stuff, anyway an easy formula to calculate theoretical maximum, so no losses in system, for RAM air is
(MPH)^2 X .0000176 That will give you a number in PSI. So as you can see it's no magical free turbo at least not at any speed your going to reach on a motorcycle. At 200mph the maximum psi is going to be around 0.7 PSI at 150mph it's 0.4 PSI and at 100mph it's only 0.176 PSI. A LOW boost turbo is around 7psi so as you can see it's not that much but in racing every little bit counts.
misnblu
Re: Theoretically maximum RAM air pressure explaine
Post by misnblu »
VT1000r wrote: Tue Dec 01, 2020 10:22 am Hello, I posted something about RAM air exactly 364 days ago it just so happened to be my last post until now. I've done a lot of research on RAM air and studying fluid dynamics quite a bit in general like venturi effect and aerodynamic drag for subsonic vehicles, very interesting stuff, anyway an easy formula to calculate theoretical maximum, so no losses in system, for RAM air is
(MPH)^2 X .0000176 That will give you a number in PSI. So as you can see it's no magical free turbo at least not at any speed your going to reach on a motorcycle. At 200mph the maximum psi is going to be around .7 PSI at 150mph it's .4 PSI and at 100mph it's only .176 PSI. A LOW boost turbo is around 7psi so as you can see it's not that much but in racing every little bit counts.
Good information.
Now I can take this bit of information to some of the car forum guys that think ram air is useful for their engines and all their scoops and funneling they do. :lol: :thumbup:
https://www.dwn4lif.com
My website 👆
i seem to remember ,i think it was Roger who mentioned that it has little to no effect until the bike reaches 110mph? but as you say for racing it all counts.
It's right at the top of the rev range when a trick motor can't suck enough air 'cause the airbox is empty. 1 atm is the figure I have in my head but I haven't worked that out in psi. I think mine could maybe cope with a bit more air but I'd try a programmable ECU first.
freeridenick wrote: Wed Dec 02, 2020 7:49 pm It's right at the top of the rev range when a trick motor can't suck enough air 'cause the airbox is empty. 1 atm is the figure I have in my head but I haven't worked that out in psi. I think mine could maybe cope with a bit more air but I'd try a programmable ECU first.
1 atm is 14.7 psia at sea level :thumbup:
8541Hawk wrote: Wed Dec 02, 2020 9:15 pm
So way off the formula above. Interesting. I'll see if I can find the source of the figure I had in my head.
