Welding a plate to bottom of side stand?
Has anyone successfully using an Arc Welder, welded mild steel to our Firestorm/Superhawk side stand :?:
I'm intending to weld a 6mm thick plate (mild steel) to the foot of the stand to make the bike more upright.
Any advice on what rods work would be very helpful,
Cheers,
Re: Welding a plate to bottom of side stand?
It's a cast iron or forged stand, not sure which.
Check this with Cheeky Kev, his welding is legendary.
what i done was drill it, popped a 8mm bolt through it and a small 10mm bit of alloy tube under the foot of the stand, job done, its been working grand for 4 years :thumbup:
tony.mon wrote: Sun Jan 31, 2021 8:31 pm It's a cast iron or forged stand, not sure which.
Thanks Tony for your reply :thumbup:
I'm thinking similar to you on the metal used for the side stand, although I'm not sure cast iron would take the abuse the stand gets, I think it would be too brittle and would snap easily, although I may be wrong on that.
I'll PM Cheekykev :thumbup:
Cheers,
fabiostar wrote: Mon Feb 01, 2021 11:09 am what i done was drill it, popped a 8mm bolt through it and a small 10mm bit of alloy tube under the foot of the stand, job done, its been working grand for 4 years :thumbup:
Thanks for that suggestion Rob :thumbup:
It may well come down to something like that, it's always good to have a plan B :)
Cheers,
MK_WF
Post by MK_WF »
I have once welded RD350 kickstarter which is a similar material to the storms sidestand.
The weld didn't last, but in case of the sidestand it's not a big deal.
No tension or bending forces acting on the weld - it basically just prevents the plate from falling down.
I'd give it a try.
Bye
Martin
cheekykev
Post by cheekykev »
Hi Chris, PM sent with info, and phone nbr if needed.
Like what you do
Do what you like
Also, try googling "big foot side stand".
There a few bolt on types on the market, that sandwich two plates onto the original foot. They are mostly designed to increase the area of the foot, but they add height, too.
MK_WF wrote: Mon Feb 01, 2021 5:56 pm I have once welded RD350 kickstarter which is a similar material to the storms sidestand.
I'd give it a try.
A good point, thanks for your input :thumbup:
Cheers,
cheekykev wrote: Mon Feb 01, 2021 7:12 pm Hi Chris, PM sent with info, and phone nbr if needed.
Thanks Kev, good man :thumbup:
tony.mon wrote: Mon Feb 01, 2021 7:16 pm Also, try googling "big foot side stand".
Good thinking Tony :)
Many thanks for that suggestion :thumbup:
Cheers,
Chris, I think it's a forging rather than cast and when I welded a new boot loop onto it it welded fine with just arc welding.
AMCQ46 wrote: Mon Feb 01, 2021 10:34 pm Chris, I think it's a forging rather than cast and when I welded a new boot loop onto it it welded fine with just arc welding.
That's sounding promising Al :thumbup:
Thanks for your reply,
Cheers,
Er just fit a Blackbird stand instant uprightness... OK you might have to adapte the prong as its really short but looks better than a club foot...
MacV2 wrote: Tue Feb 02, 2021 1:01 pm Er just fit a Blackbird stand instant uprightness... OK you might have to adapte the prong as its really short but looks better than a club foot...
Not to a club racer...
