My vtr has recently started to run very roughly on start up and will only start with the choke.On releasing the choke engine cuts out.Prior to this the engine was revving and performing normally but would sometimes cut out when trying to engage first gear.
It has a K&N air filter fitted on checking it looked ok,unfortunately,I don't know what stage dynojet kit was fitted only that it has been dynojetted,before tackling the carbs would appreciate any advice.cheers
Running very rough on startup
Re: Running very rough on startup
No fuel reaching the carbs. Check the vacuum line is connected correctly, to the 9 o'clock position on the fuel tap and not 6 o'clock.
did this start at the same time the K&N was fitted? or had the tank of for any reason?
- nachtjaeger13
I bought the bike with the kand n already fitted in October 2019.
- nachtjaeger13
If it runs with the choke on, it could well be a blocked/gummed up pilot jet, especially if it's been stud for a while.
Like what you do
Do what you like He who wonders isn't always lost
