SOLD Moriwaki titanium header, collector and high level right side link pipe
Moderator: VTRDark
- freeridenick
Don't get excited about this as it's only good for spares. The front header is a straight fit but need cleaning up. The collector is knackered and only fit for rough dimensions to get one made - the metal has fatigued and kept cracking despite being welded up. The right side high level link pipe is in good condition but the mounting bracket for the foot rest has obviously snapped at the bolt hole and another hole drilled lower down. I'd cut this off if I was going to use it. I've no idea how much to ask for this as it dependant on what someone has. There is a set on Jauce that's missing the right hand link pipe so one good set out of two poor ones is possible - https://www.jauce.com/auction/w429192120.
You do not have the required permissions to view the files attached to this post.
