Where does this fit?
bingo808
Post by bingo808 »
Hi
I managed to buy a 2nd hand battery cover for my bike. I can see where one part covers the battery. Where does the other flap go?
Someone put it together, so I should be able to pull it apart.
Mototrick
Re: Where does this fit?
Post by Mototrick »
I can't work out what that is from the photo :confused
I've come to work in the car today, so i can't compare it to my VTR right now.
Mototrick
Post by Mototrick »
I think that bit should point down, towards the floor, not up in the air. Like in this diagram https://www.fowlersparts.co.uk/parts/51 ... ear-fender
Mototrick wrote: Wed Sep 22, 2021 11:39 am I think that bit should point down, towards the floor, not up in the air. Like in this diagram https://www.fowlersparts.co.uk/parts/51 ... ear-fender
Mototrick is correct.
You need to remove the battery [remove the negative (-) side first then the positive(+) battery connections] and lift the battery out. You need to disconnect the small fuse box first IIRC from it's fixing, it unclips using a small flat blade screwdriver at the the back of it to release the clip. Once released you can then hold it up out of the way so the battery clears it when you lift it out.
Once the battery is out you can see the 4 holes in the existing plastics where the 4 pins on your cover fit to hold it in place,
