Radiator Hoses
mjvw
Radiator Hoses
Post by mjvw »
Any one used [urlhttps://www.as3performance.co.uk/silicone-radiator-hoses/][/url] Thinking about changing my OEM set, also advice hose clips they sell SS kit for £45ish seems a little steep might be able to purcashase indivdualy?
Thanks Storming About. :D :D
Storming About :thumbup:
Re: Radiator Hoses
mjvw wrote: Sat Oct 23, 2021 10:55 am Any one used [urlhttps://www.as3performance.co.uk/silicone-radiator-hoses/][/url] Thinking about changing my OEM set, also advice hose clips they sell SS kit for £45ish seems a little steep might be able to purcashase indivdualy?
Silcone hoses need clips with a rounded edge...
The ones they sell are the corect ones.
Normal clips will cut in & fek the hoses up. cheaper yes but then you'll need to replace the hoses again so hardly a bargain...
mjvw
Re: Radiator Hoses
Post by mjvw »
MacV2 wrote: Sat Oct 23, 2021 11:38 am
Thanks will get the correct clip set have you used these hoses? The other hose suppliers are little out of my wallet range.
Re: Radiator Hoses
As I understand it Samco hoses are better quality, and more expensive I know. However it is one of those jobs you only want to be doing very very occasionally, so I felt it worth mentioning this option.
mjvw
Re: Radiator Hoses
Post by mjvw »
sirch345 wrote: Sat Oct 23, 2021 11:59 am As I understand it Samco hoses are better quality, and more expensive I know. However it is one of those jobs you only want to be doing very very occasionally, so I felt it worth mentioning this option.
Yep Samco are the ones out of my price bracket. Defo giving the cheap import ones a miss.
