Engine bogs down
bingo808
Engine bogs down
Post by bingo808 »
Hi
Well, I think I balanced the carbies. Not 100% confident.
Today I fired up the beast and it idled a bit low after about a minute. Tried to up the idle. All this does is push on the throttle plate, right?
New problem. After I adjusted the idle, the motor would bog down on opening the throttle. Like really bog down. Then I let the throttle go and it idles for a bit then conks out.
Is there a idle mixture screw for these motors? This "bogging down" happens after 1-2 minutes of running. Motor gets barely warm.
Someone put it together, so I should be able to pull it apart.
Re: Engine bogs down
Got the petrol tap vac line on the sideways pointing spigot or straight down?
The straight down one is a drain, nothing should be connected there.
tony.mon wrote: Fri Nov 19, 2021 1:55 pm Got the petrol tap vac line on the sideways pointing spigot or straight down?
Funny you should mention that, I was thinking exactly the same thing,
sirch345 wrote: Fri Nov 19, 2021 8:16 pm
It wouldn't cause bogging down as it just wouldnt run after any fule in the carbs run out...
Probably after about one & a half Thumps...
bingo808
Post by bingo808 »
Yes, I'm sure I have the vacuum line connected to the sideways spigot. All good there.
Have you tried opening the fuel cap to see if the issue goes away as it sounds like the tank vent is blocked.
bingo808
Post by bingo808 »
8541Hawk wrote: Fri Nov 19, 2021 11:17 pm Have you tried opening the fuel cap to see if the issue goes away as it sounds like the tank vent is blocked.
No, I haven't tried that. Thanks will do.
