Enlarged lower airbox £30ono posted
Moderator: VTRDark
Standard airbox lower with the cam cover vents and carb diaphragm vents deleted to increase the volume. It's a straight fit and takes the stock velocity stacks. You'll need to add filters to the cam cover vents, little oil breather filters work, and the same with the carb vents. I'll include some open foam that just needs cable-tying over the end. Works best with the open airbox lid and some engine upgrades but could be made to work with a stock engine and after market exhaust.
I've no real clue on price as airboxes are cheap but it took a fair amount of time to trim, shape and bond in the plastic that fills the holes.
You do not have the required permissions to view the files attached to this post.
