luggage
zakisbak
luggage
Post by zakisbak »
I don't want a rack/top box,tank bag,rucksack.
Anyone used a pillion seat bag?Any good?
Does a cargo net/bungees work on the pillion seat? (there seem to be small gaps under the seat that bungees may go through?)
Only talking about very light luggage,mainly a heavy chain/padlock,and a toothbrush change of underwear if I'm feeling flash :lol:
Re: luggage
There are fold out hooks under the seat.
I use Rok Straps... https://www.ebay.co.uk/itm/324995530997 ... BMoMiugfFf
You can get tail packs & look out for a Rentac rack only holds 5kg but good for strapping to.
https://www.ebay.co.uk/sch/i.html?_from ... acat=25622
Re: luggage
Also look out for a Ventura rack and bag system. It allows you to mount a 50l bag either on the pillion seat or on the rack, and when you don't want it on the bike you can quickly unscrew the rack and A frame that supports the bag.
And you can get a pillion grab rail that can fit in place of the mounting rails that remain attached to the bike, so it is a pretty versatile solution.
Re: luggage
AMCQ46 wrote: Mon Mar 14, 2022 10:50 pm Also look out for a Ventura rack and bag system. It allows you to mount a 50l bag either on the pillion seat or on the rack, and when you don't want it on the bike you can quickly unscrew the rack and A frame that supports the bag.
It pays to read thr OP post Al... ''I don't want a rack/top box,tank bag,rucksack.''
:wink:
Re: luggage
Oh Zaisbak forgot to say the tail pack I hane just has straps that go under the seat to hold it on. Yes the straps, velcro jobs, fit in the gaps on the cowl. Take the seat off, strap it on, seat back on & away you go...
zakisbak
Re: luggage
Post by zakisbak »
Thanks for replies.
I suspect as usual it will be a plastic bag/bungee affair :clap:
Re: luggage
zakisbak wrote: Tue Mar 15, 2022 5:13 pm Thanks for replies.
If you do come to Grainstorm I have one you can look at poss buy...
viewtopic.php?t=45233
Re: luggage
MacV2 wrote: Tue Mar 15, 2022 5:34 pm
A tail pack not a plastic bag, Plastic bags are avaliable 10p each... :lol:
Re: luggage
MacV2 wrote: Tue Mar 15, 2022 9:33 am
:wink:
I saw that .......... Mr Pedantic :lol: , but with the ventura you can quickly and easily take off the bag the rack or the grab rail, so you only have the hidden rails, so it is a pretty good compromise. so I thought I would be helpful for once.
Re: luggage
these are the ventura rails that remain on the bike once the quick remove parts of the rack are taken off
zakisbak
Re: luggage
Post by zakisbak »
They look ideal!
Thanks for that.
zakisbak
Re: luggage
Post by zakisbak »
Realized I have hi rise exhausts so don't think it would work.
I'll probably use backpack and bungees.
