Suspension Experiences?
Fenix
Post by Fenix »
Hi guys!
Im on the cusp of ordering in some suspension fixes for my bike, but here are a few options. I was all sorted and prepared going down the Ohlins road but apparently i can only source fork springs for it....
Locally they are telling me about Wilbers and YSS springs as well as the same in rear shocks but ive also come across Nitron.
Im about 76Kgs - 188cms tall.
Im thinking about Ohlins front fork springs to suit and a Nitron rear shock.
Does anybody else have any other suggestions? Any experience with the other brands?
Re: Suspension Experiences?
Get the forks done by Roger @Revolution Racing & a Nitron is a good fix...
I can back up what Mac said.
Rodger modified forks make a huge difference, it has taken me a long time with my transplanted Aprilia RSV4 USD forks to get back to the feeling I had with the Rodger forks.
And I have had 2 nitron shocks and rate them higher than the Ohlins. infact I sold my 1st Nitron because I had got hold of an Ohlins, I got the ohlins fully serviced and new spring for my weight, but it still wasnt as good as the Nitron was, so I sold it and got another Nitron!.
StuartWags
Post by StuartWags »
I had a blade front end (not upside down) and a Nitron. I use to crap myself every time going over the ripples on the exit of Charlies 2 at Cadwell with standard storm suspension. Completely dialed out with the mods even though the front was still a bit soft.
I think the Nitron may even be the AMCQ mentioned, as i sold it separately to the storm. I also have a Nitron on my CBR600 track bike and happy with that too
StuartWags wrote: Thu Apr 07, 2022 12:24 pm I think the Nitron may even be the AMCQ mentioned, as i sold it separately to the storm.
yes my 2nd Nitron was the one I bought off your Stuart :thumbup:
Fenix is based in Australia so I guess there must be suspension experts available over there who would be more cost effective. Try sending Kenmoore a PM, as I remember he’s done a fair amount to his Storm, including suspension.
I’ve used ktec who are based over here for weight rated springs, but as I said there’s probably someone more loca to you.
Good luck
Fenix
Post by Fenix »
Hi guys!
Yeah I'm sorry about not mentioning I'm in Australia.
I've been searching and asking around but have yet to find a place that knows the storm inside n out.
Rito, so I have decided on a Nitron shock then.
Last is to work out if someone can tweak and modify these front forks, if not, some ohlins springs and fresh oil
popkat
Post by popkat »
Ohlins or k tech springs, I’d say 0.85kg for your weight and use 10weight oil with a 140mm air gap, this will be a huge improvement over stock.
Set you forks 6-8mm further through the yokes and set static sag to 27-28mm. If you don’t drop the front lower the springs will have caused the front to be higher than it was.
With the Nitron rear shock you can adjust the length, you can go until it just nearly touches the linkage, the ride height raise will help the bike no end. But don’t go past the recommended thread length on the shock.
acrmnsm
Post by acrmnsm »
MacV2 wrote: Thu Apr 07, 2022 9:38 am Get the forks done by Roger @Revolution Racing & a Nitron is a good fix...
Link to Revolution? I can't find.
1997 Red Storm, 3 others in bits...
"Devonshire born and Devonshire bred, strong in the arm and thick in the 'ead."
acrmnsm wrote: Wed Aug 14, 2024 12:27 pm
https://www.revolutionuk.co.uk/
acrmnsm
Post by acrmnsm »
Cheers Mac
ItsaKeeper
Post by ItsaKeeper »
Thanks to the info on this forum, last Spring (no pun intended) I got my forks done by Roger and got a Nitron for the rear. My Storm is all the better for those changes, Roger is an absolute gentleman and pleasure to do business with :thumbup:
acrmnsm
Post by acrmnsm »
There is a penske vtr shock for sale near me, 500notes, but it does look cool, ride height adjustable which is attractive for some. I'll link if anyone interested.
SlingVTR
Post by SlingVTR »
Got a Maxton on mine and its stupidly better than the standard shock.
