Rev counter is not working. Need to know the cause
danielkreger
Post by danielkreger »
How to choose a pressure washer and our pick for the best 3 pressure washers
Are you looking for the best pressure washers? If so, our The King Live editorial team has good news for you! After spending days and nights conducting research, seeking out information from reliable sources, and getting advice from experts, we are pleased to provide you with useful information on how to choose a pressure washer, as well as providing our pick on the top 3 pressure washers available on the market.
How to choose a pressure washer?
A pressure washer is a sprayer that uses a high-pressure stream of water to wash siding, concrete floors, remove dust, paint, dirt, mold, mud from outdoor, and more. For most homeowners, the pressure washers which generate less than 5,000 are absolutely ideal for everyday use.
As standard, the pressure is measured in pounds per square inch (or PSI). The water flow rate is measured in Gallons per minute (or GPM). To choose the best of products, you should consider PSI and GPM to see whether an electric or a gas-powered pressure washer is best suits your needs.
A pressure washer can be powered by 2 main sources:
  • Electric: require less water (about 1-1/2 Gallon per minute) to perform light-duty tasks like washing the garage and cars.
  • Gas-powered: require about 2-3 GPM to perform heavy-duty tasks such as cleaning concrete, removing stains, and washing exterior siding for painting.
What are the best 3 pressure washers?
Scroll down to find the best products on Amazon:
1. Sun Joe SPX3001 2030 Electric Pressure Washer with hose reel ($170)
  • PSI: 2030/ GPM: 1.76
  • Weight: 32 pounds
  • Hose length: 20 feet
  • Amazon customer reviews: 4.4 out of 5 stars (on over 7,550 global ratings) – Ranked no. 1 in Pressure washers & ranked no. 74 in Patio, Lawn & Garden product category on Amazon
  • It has a great ability to perform cleaning duties from light to heavy
  • Offers detergent tank and hose reel
  • Easy to assemble and easy to use
2. Stanley SHP2150 Electric Pressure Washer ($171
  • PSI: 2150/ GPM: 1.4
  • Weight: 25.57 Pounds
  • Hose length: 25 feet
  • Durability: last for several years
  • Cleaning force is powerful: works best for outdoor furniture, vehicles, decks, siding, and more
  • It comes with a pressure washer gun, wand with nozzle fitting, swivel garden, hose adapter, and 4 different nozzles
3. Westinghouse Outdoor Power Equipment WPX2700 Gas-Powered Pressure Washer
  • PSI: 2700/ GPM: 2.3
  • Weight: 63 pounds
  • Amazon customer reviews: 4.7 out of 5 stars (on over 4,900 global ratings) – Ranked no. 6 in Pressure washers
  • Ideal for deep-cleaning decks, sidewalks, outside walls, and furniture
  • Easy to assemble, easy to use, and maneuverability
Meet one of our team members – Meredith Smith
Meredith Smith is currently an Associate Editor at The King Live. Like many others at the site, she loves creating content to share her wide range of knowledge and experience, especially in the 2 main sections: Home & Garden and Baby Care. When she has free time, she’s keen on gardening and spending time playing with her children. This is her site: https://www.linkedin.com/showcase/meredithsmith/
Contact us
Address: 4150 Portillo Rd #29, Spring Hill, FL 34608, United States
Phone: (1) 206-656-1275
Email: wikithekinglive@gmail.com
MK_WF
Re: Rev counter is not working. Need to know the cause
Post by MK_WF »
I've read people reporting blown tachs, bulbs and CDI's after reg/rec failures due to the occurring higher voltage.
Most stuff can only bear some 18V.
Maybe it's worth a try to measure charging voltage on your battery first.
Bye
Martin
