Where online can I buy suitable cabling in the correct colours and ratings for various rewiring tasks? Also the correct connector blocks? Amongst other things, I have a spare speedo sensor which someone chopped short. I want to get the sparkies at work to rewire it.
Pic is just grabbed from an Internet image. Cheers
Possibly not a source because of the US location, but it is a good resource for figuring out what the connectors are. I have purchased from them and they are a solid seller. Also go with a quality wire, more strands of copper and cross linked insulation. The wire is going to be costly, depending how much you are doing, as it will best to have a fair length of different colors and sizes. You will also need an open barrel crimping tool if replacing connectors.http://www.cycleterminal.com/index.html
I think this is the connector you posted a photo of. Fourth one down. http://www.cycleterminal.com/110-connectors.html
~ Mark Twain
