Setting timing after cam chain tensioner fail
Vtrnznelson
Post by Vtrnznelson »
Hey all, my manual cam chain tensioner popped out as whoever did it didn't locktight it!!!! Anyway I've brought new valves etc and reseated and assembled everything. However what we've discovered is that the FT and FE FI don't quite line up. When we adjust one tooth fwd or one back it's the same issue. I'm thinking that the cam chain may have stretched half a tooth or there abouts. Any suggestions on a way around this? Or do I need to buy a new chain? If new chain, is there a master link so I can thread it through without removing the alternator etc? If I have to remove the alternator etc does anyone have a video link showing how to do it?
Lot's of questions so happy if it takes a few peoples help. Cheers
Vtrnznelson
Re: Setting timing after cam chain tensioner fail
SO after more research seems that the chain is most likely stretched, so a new one will be ordered in the morning. And as there's no master link I will need to take of the alternator etc. Does anyone have a link to a video or easy to understand instructions or tips and tricks on how to do this? Much appreciated
What you are describing is fine. No need to replace the cam chain(s),
PS. Welcome aboard👍
Vtrnznelson
Thanks for the welcome Chris.
If I don't need to replace the chain then do I prioritise lining up the FE and FI or the FT? If I get the FE & FI in line then the FT is about 5 mm out
They're always a little bit out, it makes no difference to running or power, so just get it as close as you can and button it up.
Vtrnznelson wrote: Sun Jul 02, 2023 10:45 pm Thanks for the welcome Chris.
If you are thinking about which timing marks to use for the valve clearance checks now you've fitted new valves on the front cylinder head, I can't really see it will make any difference which marks you go off. If you want to be pedantic, then I guess aligning the FE and FI marks would be the ones to get exact, but as I said I doubt it will make any difference either way,
