Standard handlebars, £15 the pair or £10 each.
After market handlebars. These are slightly lower and more swept back. £15.
Starter motor. Refurbished by Agent P on the forum and I bought it from Mac as I thought mine was duff. It wasn’t in the end. Can be seen working. £50.
Starter motor. Can be seen working, but in need of refurbishment. £20.
Throttle tube. I have a vague feeling this is a 1/5-turn tube from an SP or similar, but I can’t confirm. £P&P only.
Front master cylinder and lever. Clean but might need a rebuild. £25
CBR 900 RR Fireblade rear caliper. Clean but I’m guessing would need a rebuild. Bought when I was toying with the idea of fitting a 6” rear wheel. £15.
Right side radiator. Useful as a track spare but the post for the wiring connector block has snapped off. £10.
