Amazingly simple home remedies
VTRgirl
Post by VTRgirl »
1. If you are choking on an ice cube, don't panic. Simply pour a cup of boiling water down your throat and presto. The blockage will be disappear in seconds.
2. Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
3. Avoid arguments with the little woman about lifting the toilet seat by simply using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
5. A mouse trap, placed on top of your alarm clock will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
7. Bad toothache? Smash your thumb with a hammer and you will forget about the toothache
waspy
Post by waspy »
they are very funny !!!!
It's a bad idea to take a sleeping pill & a laxative at the same time !!
