Rattling engine
Rattling engine
Hi all fitted ape ccts start engine from cold no rattle when engine warm engine rattling pull clutch in still rattling is it oil pump chain 14500 m on engine was rattling before i fitted ape ccts
- Miztaziggy
Re: Rattling engine
rattling when warm only and rattling before you fitted CCTs?
Someone will be able to inform you way better than me, but maybe tight valves? Cam chain not tight enough adjust manuals needed? Maybe bent valves already if your old CCTs had gone?
Can you post a video of the sound?
Re: Rattling engine
Before you changed the old cct's, did you check to see if one had a broken spring?
i.e was it a failure that prompted the change, or preventative?
Re: Rattling engine
Hi springs not broken changed to mcct to be safe valve clearances all ok and cam chains ok bike starts on the button can it be oil pump chain engine rattling when warm only
- Miztaziggy
Re: Rattling engine
Hi, Im also new to VTR1000s and have a rattle from the engine at very low revs (Between 1000 - 2000revs). I was advised it may be the front cct so have had it changed but just recieved a call from the bike shop to say theres no change. Its no different when the clutch is engaged and is louder when warm. The bike pulls like a train and starts first time. Any ideas would be gratefully received???
Thanks.
Thanks.
Re: Rattling engine
Have you had the bike long? is it a new noise or is it just noisier than you last bike?JWB125 wrote:Hi, Im also new to VTR1000s and have a rattle from the engine at very low revs (Between 1000 - 2000revs). I was advised it may be the front cct so have had it changed but just recieved a call from the bike shop to say theres no change. Its no different when the clutch is engaged and is louder when warm. The bike pulls like a train and starts first time. Any ideas would be gratefully received???
Thanks.
Re: Rattling engine
Hi, just had the bike, usually ride GSXR 1000s. Took it to 2 bike shops and they both thought it was the cct. My friend owns the shop its at so he wouldn't try and rip me off and said he will investigate further. Ive never owned a vtr1000 before so didn't really know what they are supposed to sound like. The only way I can describe the sound is like the rattle you get off flat slide carbs when you throttle off??
Re: Rattling engine
Well what do flat side carbs sound like??. Is the sound like a taka taka taka or a chufa chufa chufa??JWB125 wrote:Hi, just had the bike, usually ride GSXR 1000s. Took it to 2 bike shops and they both thought it was the cct. My friend owns the shop its at so he wouldn't try and rip me off and said he will investigate further. Ive never owned a vtr1000 before so didn't really know what they are supposed to sound like. The only way I can describe the sound is like the rattle you get off flat slide carbs when you throttle off??
Re: Rattling engine
A fast rattle, definately not a chuf
Re: Rattling engine
They are pretty noisy engines as standard, with a 500cc piston whinging round. But don't mess about fitting new Honda tensioners, fit some manuals to make sure you are in control of the tension. But don't be tempted to over tighten....lots of data on this in the workshop section.
Re: Rattling engine
Hi sound is coming from front pot at tick over to 2000rpm when warm no rattle when coldMiztaziggy wrote:Where does the rattle sound to be coming from?
How loud is it?
Re: Rattling engine
Hi can you let me know how you get onJWB125 wrote:Hi, just had the bike, usually ride GSXR 1000s. Took it to 2 bike shops and they both thought it was the cct. My friend owns the shop its at so he wouldn't try and rip me off and said he will investigate further. Ive never owned a vtr1000 before so didn't really know what they are supposed to sound like. The only way I can describe the sound is like the rattle you get off flat slide carbs when you throttle off??
Re: Rattling engine
Have u got manual cct's installed or standard ones?? If you have standard one then get some manual ones fitted & see if the rattle goes. If it is still there then it could be valve clearances.jd-man wrote:Hi sound is coming from front pot at tick over to 2000rpm when warm no rattle when coldMiztaziggy wrote:Where does the rattle sound to be coming from?
How loud is it?
Re: Rattling engine
Hi and thanks for the info. The bike has been fitted with a new cct and now is being re shimmed. Fingers crossed its fixed the problem. Wasn't that loud to start with but ya gotta have it right aint ya. Fingers crossed!!!
