Ive also added the new grips which make a surprising difference, better control as the old (original) grips were (in hindsight) quite slippy.
Also tidied the back end by reducing the size of the under tray and size of the number plate (though technically is illegal now but still looks a sensible size in my opinion). Stock rear indies replaced by smaller, more discreet but just as bright (almost) ones.
Re-cycled rear indies - gave to bigspanishmarty.
... and went for flush LED front indies but didn't like them so went for these - not as flush but bigger and not LED, so no probs with flash rate. I like them!
Plan now is to save up for a mod on the rear shock (new, mid-range) and up grade front forks springs/oil as it is wooly/floppy as hell - feels like tyre is flat when more than a bit of brake is used, horrible. £££££££s! Might put 4mm of spacing under current rear shock sometime soon?
Any ideas welcome!!
Griff
Enjoy!!!!
