Yes, as there's a wasted spark on the ignition system.
So assuming that you timed one cylinder out 180 crankshaft degrees, then timed the second cylinder 180 degrees out also it would still run ok.
But why would you?
timing marks
Re: timing marks
Re: timing marks
Does anybody know if a 94 cbr600 flywheel fits to Storm sprag clutch,save a bit of machining?
- benny hedges
Re: timing marks
it might fit but you will need to keep the original for the timing marks.
you may have to fit the stator as well.... tbh id be surprised if it fits but you never know.
is it to make it lighter???? if so have a look at the 'lightened flywheel' thread for machining dimensions.
over 2lb lighter and you keep the timing marks.
Re: timing marks
just to up date this
when i removed the flywheel today i found this
it explains why my timing marks were out .
the woodruff key has sheared in half allowing the flywheel to rotate on the crank
new key fitted and the lighter flywheel to
timing marks
Lol is that better than a woodie
Sorry officer
The voices made me do it
Sorry officer
- benny hedges
Re: timing marks
thats what happens when the nut isnt tightened properly
lucky you didnt wreck the stator.
timing marks
I know and I've done 4400 miles since I had it
The po bodged a lot of things on it I hope that's the last of them
Sorry officer
Sorry officer
