Spacer mod help
Vtrkidda
Spacer mod help
Post by Vtrkidda »
Ive been searching through lots of posts and pics of this mod :thumbup:
So I need a 6mm spacer on top of my rear shock to subframe ,then because im not the tallest man in the world drop my yolks 10mm or so ?
Can i use washers or should I make one out of alloy ect :confused
So This mod improves faster/ sharper turning
Loud pipes save lives!
Re: Spacer mod help
Not the best of mods if you're short in the leg, or if you still have standard front forks, as the forks bottom out easily enough without putting more weight on them by raising the rear. You can use big washers by cutting a slot in them rather than removing the shock top mount to fit them.
Using 1mm spacer will raise the rear approximatley by 4mm, so a 6mm X 4mm will equal a 24mm rear end raise.If you are going to try this mod out for yourself I would try a 2mm spacer/washer first. Yes it will quicken up the turn in.
Vtrkidda
Re: Spacer mod help
Post by Vtrkidda »
Cheers chris might try it I can always take them off :thumbup: :wink:
Styler4077
Re: Spacer mod help
Post by Styler4077 »
If your short in the leg buy my 50mm shorter rear Hagon shock. :D
"Only one life, so live it and ride a motorcycle"
leevtr
Re: Spacer mod help
Post by leevtr »
Get decent springs and oil, then read Twist of the wrist, and be a better rider....Its better to improve yourself, not the bike !!
benny hedges
Re: Spacer mod help
Post by benny hedges »
Vtrkidda wrote:Ive been searching through lots of posts and pics of this mod :thumbup:
if you want to try a spacer i have some you can have.
benny hedges
Re: Spacer mod help
btw - easiest way to fit these is to take the seat off,
undo the top shocker nut behind the tank - just enough... no need to take it off!
then with the sidestand down, pull the bike to the left & get a mate to pop the spacer under the shock.
saves fannying around trying to lever it in lol!
i wouldnt bother dropping the forks though if youre going to jack the rear.... just fitting the spacer puts a lot more load on the forks anyway so you will probably need to increase the preload too.
dropping the forks too much makes the bike Very twitchy at low speed = not a nice feeling.
and also it will stand up too straight on the sidestand and will probably fall over! :Ball Kick:
if it still wont turn in quick enough for you, fit a 160 on the rear.
Vtrkidda
Re: Spacer mod help
Post by Vtrkidda »
Now im not sure about the mod :( :think:
Can I just drop the front with out the spacer mod :thumbup:
As I a bit of a short assssss :thumbdown:
Just cant leve the bike alone tinker tinker tinker :beer:
benny hedges
Re: Spacer mod help
yeh you can drop the forks but no more than 15mm or so otherwise it ges twitchy & unstable..
you could do same as mine & accidentally fit the shock linkage upside down - that lowers it quite a bit :thumbup:
makes it handle better too imo - mine does anyway :thumbup:
Vtrkidda
Re: Spacer mod help
Post by Vtrkidda »
Thanks benny still waiting on my 15 tooth front to come then scare my self :twisted:
ive been out every waking second this week on the vtr 8O
I still dont think id keep up with you :shh:
Mad man and he was plodding 8O :(
Re: Spacer mod help
Vtrkidda wrote:Thanks benny still waiting on my 15 tooth front to come then scare my self :twisted:
(shhhh, don't tell anyone, but he brakes early, you can under him on the brakes, especially on left handers.......)
And he's colour blind when looking at dragstrip lights :lol: :lol: :lol:
Just don't fall off trying.
benny hedges
Re: Spacer mod help
tony.mon wrote:And he's colour blind when looking at dragstrip lights :lol: :lol: :lol:
er no. thts because u told me to wait for the green light you cnut! :Ball Kick:
Re: Spacer mod help
Quality!! :lol: :lol:
