Battery fitting advice
Snoogle
Post by Snoogle »
I know this might sound like a daft question but are batteries totally sealed?
Could I mount it upside down without fear of it leaking for example?
I'm not going to mount one upside down, but interested in knowing what angle I could go to as I'm looking at a custom subframe and space will be tight without laying the battery on its side :thumbup:
Re: Battery fitting advice
Steve mounted his fairly flatish, have a look here:-
http://www.vtr1000.org/phpBB3/viewtopic ... 8&start=15
Snoogle
Post by Snoogle »
Cheers Chris, just what I needed! Thanks!! :thumbup:
Or use a LiFePo lightweight one; they can be fitted any way up.
Snoogle
Post by Snoogle »
Cheers for that Tony...looks like it coule be expensive going for one of them tho.
Out of interest what's the maximum AH you'd recommend going to?
No max amps, at least 12 as they're a big lump to get rolling in the cold, but space is the limiting factor, and weight if you're bothered about that.
Snoogle
Post by Snoogle »
Thanks again Tony :thumbup:
looking at getting this...
http://www.ebay.co.uk/itm/150560449480? ... 1423.l2649
Thoughts/advice/better options appreciated :crazy:
i bought one of these last year and its great,
http://www.ebay.co.uk/itm/MOTOBATT-MBTX ... 5d320606e1
busters are selling them even cheaper £45 delivered
http://www.ebay.co.uk/itm/Motobatt-MBTX ... 4601cacebd
so unless your running extra electrics, i really don't think you need that big a battery, i one i bought was a tight squeeze to fit, they are a big battery, i haven't got a problem with bigger batts but just remember its physical size and weight....
lets us know what you go for dude.... :thumbup:
Snoogle
Post by Snoogle »
I'm not gonna have a massive amount of extra electrics, but will be running relays for the headlights and would quite like it to start on a cold morning when I go to it for work lol always found the one I have (standard replacement) used to struggle on colder mornings and if I hadn't been out for a while.
Cheers for the options though mate, but I think I'm gonna go for one with better AH than standard and I do like the fact that this one has 4 terminals. Space shouldnt be a problem as I will factor in the size of the battery when fab'ing the subframe :thumbup:
Snoogle wrote:Thanks again Tony :thumbup:
Yep, just fitted one myself.
The extra terminals are useful, and although heavy mine's holding its charge and starting my bike (with high compression pistons) easily.
Recommended.
Snoogle
Post by Snoogle »
Ordered yesterday, received today. Excellent. Only problem is it didn't come with 4 terminals, only 2. Did yours Tony? I mean the battery has 4 spaces for them to be fitted just in the additional packet there was only 2 terminal "mounts".
Snoogle wrote:Ordered yesterday, received today. Excellent. Only problem is it didn't come with 4 terminals, only 2. Did yours Tony? I mean the battery has 4 spaces for them to be fitted just in the additional packet there was only 2 terminal "mounts".
Same as mine; I used the screws and flat rectangular nuts from the old battery in the other positions.
Snoogle
Post by Snoogle »
Fair enough, no probs then. How does it strike up with this on? Bit late to test it out now lol
Rampant Lion
Post by Rampant Lion »
bigspanishmarty wrote:i bought one of these last year and its great,
Hi..gonna replace my battery soon. The Motobat one you recommend, does it fit ok into the battery box, or is the problem fitting with the larger 16amp one.
Thanks..Ian
Had: CB125. Benelli 250. Yamaha YDS7.Kawasaki Z400. Kawasaki Z650c. Kawasaki Z650B1. Kawasaki Z1300.Suzuki Bandit 1200. BMW R1100R. TDM 850 (2 off). Suzuki Bandit 1200. BMW R1100RT. Yamaha XT600.
Now: VTR 98 Storm in lovely silver....
Snoogle
Post by Snoogle »
I bought the 20ah one, it is the same width an depth but a mite taller...I think that this will only be a problem if you still have the battery box lid under the seat :thumbup:
