did you get back to me with a price for a rebuild tonytony.mon wrote:Same as mine.....
It's a good price, considering that ring sets are nearly £50 each....
But then the exchange rate to dollars isn't too bad at the moment.
As long as the bores are in good nick, all you need to buy is a full bearing set, get the bores lightly honed, and four new big end bolts.
Might as well fit a new set of valve seals while you're there, and all good for another 50K.
You should get an easy 110-115 BHP, plus torque gains.
with these pistons, maybe cams/porting/polishing and all the other bits and pieces. what sort of price would you charge for a rebuild(labour/mates rates
