F/R Brake-Clutch line copper washers sizes
Could someone advise what the correct size copper washers are needed please to change brake lines and a clutch line and a pretty please with a cherry on top for a ebay link to buy said items.
Frank Fan Club Member 001
Re: F/R Brake-Clutch line copper washers sizes
I was told a tip recently that works on hereSimon-l wrote:Could someone advise what the correct size copper washers are needed please to change brake lines and a clutch line and a pretty please with a cherry on top for a ebay link to buy said items.
take the old ones, apply heat till they are proper hot, then reuse them and tighten
Tried it Monday when doing work i think and it's worked fine no issues to report
Also when you buy new hoses they come with washers mate, my HELL, VENHILL and Goodride kits all came supplied
They are not new but recycled and as to heating them up did you do it at gas mark 9seb421 wrote:I was told a tip recently that works on hereSimon-l wrote:Could someone advise what the correct size copper washers are needed please to change brake lines and a clutch line and a pretty please with a cherry on top for a ebay link to buy said items.
Thanks for the reply mate.
I used a camping stove in the garage
That works for the copper ones, not for aluminium ones.
Hold them with a bit of wire (not insulated electrical wire, dummy!) instead of using pliers; you'll also soften the pliers......
And let them cool down slowly, don';t quench them in water or oil as they will just harden again.
It's called annealing.
- thumperslaw
Or buy new ones
Only about 50p from HEL brake lines
If any more give us a call i got loads
Well 500 to be fair
Well 500 to be fair
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
