F/R Brake-Clutch line copper washers sizes
Simon-l
Post by Simon-l »
Could someone advise what the correct size copper washers are needed please to change brake lines and a clutch line and a pretty please with a cherry on top for a ebay link to buy said items.
Frank Fan Club Member 001
seb421
Re: F/R Brake-Clutch line copper washers sizes
Post by seb421 »
Simon-l wrote:Could someone advise what the correct size copper washers are needed please to change brake lines and a clutch line and a pretty please with a cherry on top for a ebay link to buy said items.
I was told a tip recently that works on here
take the old ones, apply heat till they are proper hot, then reuse them and tighten
Tried it Monday when doing work i think and it's worked fine no issues to report :)
Also when you buy new hoses they come with washers mate, my HELL, VENHILL and Goodride kits all came supplied
Simon-l
Post by Simon-l »
They are not new but recycled and as to heating them up did you do it at gas mark 9 :lol:
Thanks for the reply mate.
seb421
Post by seb421 »
I used a camping stove in the garage
That works for the copper ones, not for aluminium ones.
Hold them with a bit of wire (not insulated electrical wire, dummy!) instead of using pliers; you'll also soften the pliers......
And let them cool down slowly, don';t quench them in water or oil as they will just harden again.
It's called annealing. :angel:
thumperslaw
Post by thumperslaw »
Or buy new ones
Only about 50p from HEL brake lines
If any more give us a call i got loads
Well 500 to be fair :D
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
