Spraying radiators
Spraying radiators
Just wondering will i be okay just getting high heat spray paint to do my radiators with ? or will this still peel and look bad ?
Re: Spraying radiators
No
frost.co.uk do a radiator spray
It doesn't interfere with the cooling properties
ive got a can of barbecue black high heat stuff wnt i be okay using that like ?? i was gonna ask about the fillament bits wasnt sure if cud spray them bits or not but have it all off can ready just dunno if its a go or not ha ha
In an ideal world use radiator spray, but I don't think any other heat resistant spray would do much harm as long as it's not sprayed so thick as to clog up all the fins. It may get a bit hotter, it just means the fan will kick in more often.
i used normal spray paint on mine no problem with over heating
bikes bought dead or alive crash damged , none runners , abandond projects
Do remember that the radiator is aluminium
Most paint is not designed to go straight onto it
good luck
good luck
i have a can of plasti-kote woodstove its a can my neighbour gave me as he only used a little of the can ?
Most times any paint will stick
However, after a while, just like any alloy, the paint starts to peel off
Using the correct paint, or correct undercoat should stop this happening
Open the box, or gamble the decision is yours
That plasticoat is good stuff but not for radiators
Do a bit of research on tinterweb with regards to painting alluminium
+1. Any aluminium surface will have a layer of oxidisation on it, you'll be asking the paint to stick to that, not aluminium.Flatline wrote:Most times any paint will stick
Mind you, it's no big job to pull the rads off and respray every couple of years or so.
ive covered the filiment area and sprayed rnd it .. as sum1 sed i cud cause problems to the cooling effect if i spray them ? but it looks odd leaving the main area horrid silver lol
i assume the main exaust pipe coming off the engine going underneath cudnt be sprayed with this type of paint ? that wud peel off on like 1 ride out wudnt it ? lol
Again, if you go to frost.co.uk, they sell exhaust manifold paint as well as radiator paint, even wilco motosave sell vht spray
Tony mentioned it's not a big job to do them every couple of years...................but why not do it correct the first time![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
