manual cct
dave09
manual cct
Post by dave09 »
Hi all just wanted some info on how tight manual cct should be are we talking finger tight :clap:
im worried when i die my wife will sell my bike for what i said i payed for it
Re: manual cct
You should have 7mm play in the cam chain between The cam sprockets
Finger tight is sometime to tight .
So it's best to remove the cam covers and the top guide to measure the slack
Only do one cylinder at a time making sure its in tdc before hand
lumpyv
Re: manual cct
Post by lumpyv »
if you know what you are doing (i dont !) you can do it with the engine running by ear. i,ve seen the mon meister do it.
Re: manual cct
One persons finger tight is different from another persons finger tight, too much room for error. Best to do as Lloydie suggested and remove the cam covers and get a ruler out. :thumbup:
You can also double check that you are definitely at TDC by the position of the cam lobes as well.
Re: manual cct
The best method I have heard of to get the correct tension is this (not mine, but can't remember who to credit)
Do the back one as per the rules. Set tdc, take off the cam cover and take off the chain guide so you can measure the chain slack. But the new trick is to not try and work out what finger tight is, it is to loctite the bolt, then wind in by hand till the chain is tight and then mark the screw with a marker pen and count the number of turns you need to unwind the bolt till you get 7mm slack. This then gives you the way to set the tension on the front cyl without taking the cam cover off.
Hope it makes sense :thumbup:
dave09
Re: manual cct
Post by dave09 »
cheers for the great answers much appreciated will be doing the job as i have a week off and can get the bike in the workshop.
Re: manual cct
Dave, make sure you follow this procedure for setting the valve timing:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
dave09
Re: manual cct
Post by dave09 »
sirch345 wrote:Dave, make sure you follow this procedure for setting the valve timing:-
cheers for the great info chris will be checking them soon as the previous owner said he done them but would rather check for peace of mind
