burty
Posts: 49 Joined: Fri Jul 13, 2012 6:45 pm
Post
by burty » Tue Jul 31, 2012 8:04 pm
i`ve got some new grips for the storm gettin the old one`s off is not a problem "pass the stanley blade" any usefull tips on slidin the new ones on would be welcome obviously can`t use oil etc as i will never be able to accelerate again
was thinkin maybe heating them up in boiling water first don`t fancy spending all day saturday in a battle of will`s with the bike only to end up with a scratched tank and broken fingers
Posts: 7895 Joined: Sat Feb 11, 2006 2:43 pm
Post
by Wicky » Tue Jul 31, 2012 8:12 pm
Use hairspray to fix the new uns on.
Posts: 22415 Joined: Mon Aug 25, 2003 10:35 pm
Post
by sirch345 » Tue Jul 31, 2012 8:22 pm
Wicky wrote: Use hairspray to fix the new uns on.
+ 1
Posts: 20010 Joined: Sun Mar 18, 2012 9:24 pm
Post
by VTRDark » Tue Jul 31, 2012 8:23 pm
A bit of lady's hairspray works a treat.
Whatever you do don't use fairy liquid, your grips will never stick.
burty
Post
by burty » Tue Jul 31, 2012 10:01 pm
cybercarl wrote: A bit of lady's hairspray works a treat.
does it help the grips to slide on
Post
by VTRDark » Tue Jul 31, 2012 10:03 pm
It does indeed and dries out once they are on so they don't slip about.
Posts: 16745 Joined: Mon May 11, 2009 4:54 pm
Post
by AMCQ46 » Tue Jul 31, 2012 10:07 pm
+3 on the hairspray
Posts: 20928 Joined: Mon Jan 17, 2011 11:16 pm
Post
by lloydie » Wed Aug 01, 2012 9:52 am
I'm sure you can get it in different colours too :-)
Post
by AMCQ46 » Wed Aug 01, 2012 10:05 am
and with glitter in if you like that sort of thing
simo
Posts: 1198 Joined: Sat Feb 06, 2010 5:58 pm
Post
by simo » Wed Aug 01, 2012 12:13 pm
Hair spray sounds a good idea. I usually get the grip on a half inch and stick the air line nozzle between bar and grip and with your hand over the other end ready to push and make it air tight give it a blast. Works great.
Theres A Hare in The Turnips.
burty
Post
by burty » Wed Aug 01, 2012 6:54 pm
ok thanks for the advice boys hairspray it is then
alternative_vtr
Posts: 317 Joined: Sat Jul 14, 2012 12:35 pm
Post
by alternative_vtr » Sun Aug 12, 2012 8:01 pm
Use either hairspray or clear laquer is good too.
KTM Duke 690ABS in White
