What bar end weights?
Rob
Post by Rob »
Maybe because the engine is quite refined for a twin I haven't noticed much difference using some bling aluminium ones to replace the (damaged) original ones.
(Or maybe it's because compared to the Griso it feels incredibly smooth!!)
Do they have any other function apart from reducing vibration? (Apart from protecting the bars of course!)
Anyone fitted anything different from standard and noticed a marked increase or reduction in vibration?
I have a condition that causes me problems with my hands when the temperature drops and vibration seems to make it worse. Heated grips are of course heavenly and if I could do it stylishly I would fit handguards......
'02 VTR1000-FY Yellow.
seb421
Re: What bar end weights?
Post by seb421 »
On the original bars with the Firestorm forks I replaces them with billet ones can't say as I noticed a difference tbh
Gone back to normal items on the blade forks no real reason other than they came with the 954 bars
Sent from the Bat Cave via Cup and String
tasum
Post by tasum »
does anyone know what the original ones weigh? at work so can't weigh mine at mo, thinking of some different ones, but wondering about the weight before i tackle the fitting issue
slow is smooth, smooth is fast
Raynaud's?
Standard ones are quite heavy to damp vibration. Most aftermarket are relatively lightweight so might not do the job as well as OEM
How I cope with winter inc heated grips
orig ones are steel, so if you put aftermarket Aluminium ones on they will have to be a good bit bigger to even weigh the same as the stock ones.
I have fitted bigger steel aftermarket ones, and that helps vibrations [but my bike is worse than others normally!].
This is my first year after 36 yrs biking that I have got heated grips and I am kicking myself for not doing it earier..........bloody briliant, even in summer early morning or evening as the temp drops I pop them on low and hands love it :D
chric
Post by chric »
yep wish I had bought heated grips sooner love them on the storm fitted other day just got to remeber to turn them off :oops: :lol:
AMCQ46 wrote:orig ones are steel, so if you put aftermarket Aluminium ones on they will have to be a good bit bigger to even weigh the same as the stock ones.
AAhhhh poor old sod, are your little pinkies getting cold? Circulation can be a problem for elder gents!
:beer:
Rob
Post by Rob »
Wicky wrote:Raynaud's?
It is indeed. I'm also having problems with my thumb joints which are being treated for Psoriatic Arthritis but I'm wondering if this is actually related to the Reynaud's and caused by vibration. I really should get some Renthal bars - won't help the vibration but will take the weight off my hands.
Those covers look great, what are they?
:beer:
Cheers kev, its not often you get to say this to a blue bike owner, but i will let you take the lead (on this getting old lark. :lol: ).....Just checked, nope I'm still not a granddad :D :Beer Popcorn:
[youtube][/youtube]
:lol: :lol:
