Braided hoses
chric
Braided hoses
Post by chric »
Braided hoses
Are they hard to fit?
Rear looks easy but front on mine as one going to each cylinder as standard is this normal or is it because its a 2003 :?:
Re: Braided hoses
Standard on the 2003 is one pipe down to a splitter on the bottom yoke then a hose to each caliper. The race set up is two seperate hoses from master cylinder down to the calipers. The braided hoses are easy to fit, just be careful when draining/filling/bleeding the system.
pinkyfloyd
Re: Braided hoses
Post by pinkyfloyd »
As above said. They are easy to do. I set up the race set for mine. 2 from lever, one to each caliper and if I can do it anyone can.
chric
Re: Braided hoses
Post by chric »
cheers for advise no doubt ill be bugging you lot next week when i get them im going for these.
http://www.ebay.co.uk/itm/Goodridge-Bra ... 030wt_1265
lumpyv
Re: Braided hoses
Post by lumpyv »
the fitting is no problem but work out and familiarise yourself with how to go about bleeding them (or get jonesy to help you, like i did)
good luck. :thumbup:
chric
Re: Braided hoses
Post by chric »
How do you bleed them then that was going to be my question next week :lol:
lumpyv
Re: Braided hoses
Post by lumpyv »
well your trying to purge the system of air bubbles so you have to pump the air out by opening and closing the bleed nipples and pumping whilst making sure the reservoir is kept topped up. its really important to get it done properly so get i,d get better advice than mine if i were you. having two of you is quite handy
Rob
Re: Braided hoses
Post by Rob »
Try and beg steal or borrow a Mityvac vacuum pump. Trying to pump through with the lever is a pain as it moves very little fluid. The pump sucks it through from the bleed nipple, just keep the reservoir topped up. Used it on mine when I fitted braided hoses, it was a doddle. You could buy one, not cheap but a good investment.
While you're messing about with brake fluid replace the fluid in the rear brake and the clutch as well if it hasn't been done recently :thumbup:
'02 VTR1000-FY Yellow.
Re: Braided hoses
Make sure you put the copper washers on both sides of the banjos at the master cylinder so there should be three with the two lines. One on the inside, then banjo, another washer, banjo, and another washer on the outside under the bolt.
With regards to bleeding, instead of me explaining have a read here http://www.vtr1000.org/phpBB3/viewtopic ... ing+brakes it may be of some use. :thumbup:
Re: Braided hoses
Get one of these...
http://www.ebay.co.uk/itm/Large-Syringe ... 1c2912745f
When the new hoses are on & bolted up, fill from the bleed nipple with the syringe pushing the fluid up through the system & therefore expelling the air upward out of the MC.
Cheap & easy way to do it, as used & recommended by Professor of Breaking Jonesy & so simple even a spanner monkey-brains like me can do it. :thumbup:
chric
Re: Braided hoses
Post by chric »
ill get one of them cheers :thumbup:
