Thanks for help in advance and of course any funny comments which will brighten up the problem
yes a photo of the rattle would be good, and interesting to see.....Wicky wrote:Photos of the metallic click/rattle sound would help....
OkAMCQ46 wrote:Rob, dont try and undo the nuts, use a nut splitter then you will have no problems
Steve try getting a nut welded on, that might work
The smaller one of these will work http://www.ebay.co.uk/itm/2-Broken-Dama ... 19d2f2bebaRob wrote:OkAMCQ46 wrote:Rob, dont try and undo the nuts, use a nut splitter then you will have no problems
Steve try getting a nut welded on, that might work![]()
What nut splitter do you recommend for a flange nut?
Would you replace the nuts with different ones?
Am I likely to need a new gasket (between pipe & head)? (18291-MM8-880)
I would like a couple of packers 18392-MG7-750P. Any alternatives apart from David Silver ones at £6 each?
Sorry for all the question![]()
My pipes are a bit rough, with a cleanup and paint they should hopefully last a few more years. I used to clean them with Autosol but it's a bit past that now
Or do it on the cheap like I didts never past it . as you can get them sand blasted they come up very well .
Thanks, worth getting some anyway for that priceAMCQ46 wrote:The smaller one of these will work http://www.ebay.co.uk/itm/2-Broken-Dama ... 19d2f2beba
