balance weight stickers
does anyone know whats the best way of gettin the old glue/foam off the rims without scratching etc , ive tried wd40 but no use , bit of a silly one i know but cause its there , itll bug me everytime i clean the wheels.....cheers
Re: balance weight stickers
white spirit, any tar/glue remover from a motor factors/halfords, you could also heat it up with a hairdryer and peel it off.....
cheers marty il give it a go
LOL I recently had the same problem and as I did not have any glue/tar remover I ended up picking and scraping it off with my fingernail.
Most solvents will do the job - A bit of lighter fluid or dip a bit of rag in your tank....
Careful if you're using solvents on paint, but if they're powdercoated you can use brake cleaner, trike or paraffin, even white spirit should do it.
Don't get it on tyres, either....
- Saintsman27
Hi I think a small domestic steam gun with narrow pressure nozzle
would be ideal..steam u/pressure they would see orf your glue / foam .If you dont have one
they are not expensive and have hundreds of uses , quick to heat up for steam, safe and easy peasey to
use ... used for de-icing freezers , oven and cleaning about the home. .have a go with one of them bud
Alb
Alb
Some of this
With some of this
Turned this
Into this
then i polsihed them up with this
And made them nice again
Then i applied carpro delux and a layer of milgior wax
You will also need a tub of this comes free
and like carl said finger nails help or i used a old rag aswell and used friction
But no afters
With some of this
Turned this
Into this
But no afters
try cooking oil with some tissue
petrol on a rag . dab it on then rub it off .
cheers guys can you tell me where i can get an of that elbow grease
Same shop that sells Tartan Paint, a long weight, left handed screwdrivers & possibly forcandels...marty b wrote:cheers guys can you tell me where i can get an of that elbow grease
