Aluminuim repair
Flatline
Aluminuim repair
Post by Flatline »
Thought you guys would be interested in the repair I have done to the fairing bracket
I have used Durafix: http://durafix.co.uk/
I am sure there are other makes
Filed down the ends, then used a wire brush with stainless steel wires to clean it up
Placed in a vice making sure it is all lined up
Used a plumbers gas torch to heat up the parts and when hot enough let the rod melt into the joint
Filed down the over fill and bobs your uncle
Now fitted to the bike so let's see if it holds up
Hope you found this useful
Re: Aluminuim repair
It's meant to be very good stuff
And looks like you've done a good job
seb421
Post by seb421 »
if it doesnt give me a shout and ill sent you the ones i have mate :thumbup: looks a nice repair tho mate
the old youtube video for that stuff was great
darkember
Post by darkember »
Hey Flatline I hope that part is not too visible your filing is a bit rough round the edges :biggrin :biggrin :biggrin
It will be interesting to see whether it holds together. I have used Durafix as a filler but not to fix bits which are load bearing.
darkember
Post by darkember »
Kev L wrote:It will be interesting to see whether it holds together. I have used Durafix as a filler but not to fix bits which are load bearing.
Check the videos of the stuff. You can even drill out stripped threaded bolt holes fill the hole & push the bolt back in & hey presto it forms a new thread. Could be the end of helicoils. I bet if Flatline were to try & hammer the end off he would buckle the whole component before it would break at the welded joint.
Flatline
Post by Flatline »
darkember wrote:Hey Flatline I hope that part is not too visible your filing is a bit rough round the edges :biggrin :biggrin :biggrin
Yeh its hidden so I didnt bother to finish it :thumbup:
Flatline
Post by Flatline »
Well, this seems to have held up ok
Been on a while and covered a fair few miles
So looks like it works
Result!
Result fella, well done. Good to know it works well.
But what's it like on a structural part ?
Flatline
Post by Flatline »
Quick update on this
Still working ok
Good
