Changing rear shock. What to check at same time?
Flatline
Post by Flatline »
I will be changing my rear shock soon
As I will have gone to the effort of taking stuff apart to do the job, is there anything else that can/should be changed/serviced at the same time?
Re: Changing rear shock. What to check at same time?
The linkages give them a good look over .
Miztaziggy
Post by Miztaziggy »
I would replace the bearings in the link too. There are about 3 or 4 to do.
bazza696
Post by bazza696 »
Flatline wrote:I will be changing my rear shock soon
I would say check the bearings in the swing arm and pro link for plenty of grease, also check or replace the graphite bearing in the engine casing where the swing arm goes through.
Wicky's wore out and started knocking but solved the problem when he fitted his Ohlins, think there is a picture on here of the bearing in question.
darkember
Post by darkember »
About the needle roller bearings in the alluminun triangle linkage. What is the best tool to extract them as they are really soft & collapse easily. I know have already attempted on a spare linkage??
I took mine to a workshop so they could get pressed out and new uns inserted.
darkember wrote:About the needle roller bearings in the alluminun triangle linkage. What is the best tool to extract them as they are really soft & collapse easily. I know have already attempted on a spare linkage??
darkember
Post by darkember »
Wicky wrote:I took mine to a workshop so they could get pressed out and new uns inserted.
I thought as much :thumbup:
Miztaziggy
I just used a socket that was about the same size, put it into a vice and hammered it through, it's quite easy.
It's much harder to get the new ones in. I had to put the bearings in the freezer and heat up the link in the oven. Even then it took quite a few good smacks with a hammer on a wood block to push it into place.
darkember
Post by darkember »
That sounds barbaric. Also there looks to be a raised ridge in the long section of the triangle which will mean hammering it through with a socket not possible.
Miztaziggy
darkember wrote:That sounds barbaric. Also this means you will need to hammer the old bearing all the way across the long section of the triangle, not a pleasant prospect.
Hammering the old one out really wasn't that hard.
Getting the new one in is the hard part.
Miztaziggy
See this Flatty
You need to be replacing numbers 20 (4 of) and 18 (1 of). Might also be worth changing 19 if you dont get a new one with the new shock. You will also need 21 (8 of) to seal the ends.
You can reuse parts 5, 6, 8 and just give them a really good clean.
Flatline
Post by Flatline »
Wish I'd never asked
As long as they are not broken up or starting to disintegrate just give the whole lot an extreme clean. Maybe soak it all in paraffin overnight, scrub it all up. Make sure all the rollers are working, re-grease everything and just put new seals on. No need to change things if it's all working and functioning fine. :thumbup:
Flatline
Post by Flatline »
:beer: :beer: :beer:
Flatline
Post by Flatline »
