Idle dropping
Idle dropping
The idle on my bike keeps messing about, it does need the carbs balanced and i have gauges ordered, when i bought the bike it felt like it was gonna stall so i checked up and the idle was to low(900), i adjusted the idle when she was warm to 1100 - 1200 rpm, this was fine for a couple of days then the idle dropped again and the bike was near stalling, could this be down to the carbs needing balanced or a throttle position sensor issue, only other thing i can think is that the screw for adjusting the idle is moving with the vibrations,has anyone else experienced this issue?
Re: Idle dropping
For now you will just have to raise the idle a bit but carb balance, adjusting the TPS and a general tune up is what you need. It's also worth giving the carbs a good clean out with some carbs cleaning spray if they have not been done. Make sure the air filter is not blocked. I doubt the idle adjustment screw is moving. You may want to sort out the front vacuum take off for ease of use with carb balancing while waiting for your gauges.
Some more useful links at the bottom of this post.
http://www.vtr1000.org/phpBB3/viewtopic ... 14#p238578
Re: Idle dropping
The idle adjuster doesn't move by itself, so it's something else.
If idle has dropped over the course of a day or so it sounds possible that you could have a split in a vacuum line, maybe in a diaphragm, either fuel tap or carb top diaphragms.
If it's still running apart from that then leave it until you get the balancer, and check it all at once.
Re: Idle dropping
Thanks for the replies, that link is excellent,gauges should be here tomorrow, il have a good poke around and check everything out, hopefully its somthing silly,the guy I bought the bike off wasnt into the service side of things so a good clean out would be a good idea,thanks again for pointing me in right direction
