Just a quickie....
Thinking about changing the front master cylinder on my bike for a little more power to the front brakes but will I need a different banjo bolt for the brake lines if I was to get say a 19mm cylinder?
Daft question but wanted to be 100% sure.
Question on brake master cylinder...
Re: Question on brake master cylinder...
A larger diameter MC with stock calipers will only result in increased lever effort (and will, in fact, REDUCE power)......
Don't do it ,
Change the callipers and master to cbr600f4i that will work best .
Just changing the master to a bigger one will make the lever harder and doing so will reduce feel .
Most banjo bolts are the same but there are a few that are different.
If it is another Honda master, it will bolt right up.
Brembo, you will need a new one.
Other manufacturers, just ask
Oh and I agree with these guys.... a large master is not the way to go..... you will end up with the classic "wooden" brakes.
If only $$ for one thing, then due the calipers. The best is a complete system so it's matched
Cheers fellas. I was just looking at AMcQ's thread on brake upgrades and checking on ebay but I can not find the CBR600f4i callipers and MC on there
Another one you can look for is the non radial 600rr calipers and master. They are the same as SP2 brakes but with an integrated fluid res. on the master.
look for cbr 600 brake calipers http://www.ebay.co.uk/itm/Honda-CBR-600 ... 3ccdc23aba
or any of the standard mount calipers here: http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
