crankshaft end cap
ebenviljoen
crankshaft end cap
Post by ebenviljoen »
Help chaps, trying to do cct but the crankshaft end cap aint coming off. Compltely stripped now and hammer and chissel not getting it off either. Inspection cap came off. I was thinking of taking the altenator cover off and tap a thread from the back and bolt to try and screw it out. Can i just take the whole cover off? And where can i buy a new cap? Cant see any?? Cheers
Re: crankshaft end cap
Try with a centre punch to make some holes with which to get some 'grip' to drift the cap round and out. As TonyM demonstrates below
Replacements can be had from http://www.davidsilverspares.co.uk or gl_s_r might have some of his special versions.
darkember
Post by darkember »
Ok once you get it out PM gl_s_r he makes a mean looking set of titanium replacements well worth their weight in gold.
darkember wrote:Ok once you get it out PM gl_s_r he makes a mean looking set of titanium replacements well worth their weight in gold.
Now why did you have to show me these.......
E.Marquez
Post by E.Marquez »
Drill a hole, 5~6mm in dia, about 4mm deep. Then use a center pin punch and hammer to "turn" the cap.. drill your hole about 8mm in from the outside edge, and do not go too deep or you will drill into the side cover.
Common problem on a lot of bikes, and this method has never failed to work at getting them out... done a few VTR's this faw as well.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
I had the exact same issue today with Mac's new Drooper bike as I was swapping cct's from one bike to the other. I ended up using a centre punch but this just started chewing it all up. I then applied a bit of propane and then used the centre punch/chisel to get it out. A bit of heat helps. And don't hit it too close to the the outer edge. :thumbup:
ebenviljoen
thanks chaps, ill post to how I get on! tell you what though, was inventing swear words yesterday i was that angry!!! lol :lol:
If you want some standard plugs to replace your chewed up ones I have spares you can have for postage.
ebenviljoen
Kev L wrote:If you want some standard plugs to replace your chewed up ones I have spares you can have for postage.
Halo mate,
Yeah that'l be great, don't mind paying for them either :thumbup: Can't send PM's yet though so hope you read this! lol
I will pm you my e mail address mate. I believe you can receive but not send.
Xenocide
Post by Xenocide »
I found "gently" heating the casing was all it needed to let mine come out (and alot of hammering :p).
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
It does happen to all of us.....
ebenviljoen
lol little devil things aren't they. Ill post a pic of mine too, something to be proud of!!! :lol:
When you put new ones on, use a bit of copper slip and don't overtighten them. :thumbup:
ebenviljoen
[quote="cybercarl"]When you put new ones on, use a bit of copper slip and don't overtighten them. :thumbup:
(:-})[/quote
Will do mate thanks :thumbup:
