brakes help
thumperslaw
brakes help
Post by thumperslaw »
Are the 929/954 brakes the same as the sp-1/2?
Going on my 929 forks i've got
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Re: brakes help
have a look at the table in 1st post here http://www.vtr1000.org/phpBB3/viewtopic ... 94#p123094
thumperslaw
Re: brakes help
AMCQ46 wrote:have a look at the table in 1st post here http://www.vtr1000.org/phpBB3/viewtopic ... 94#p123094
Just looked but can't work out if the mounting holes are the same on sp1/2 as they are 954/929
K100 "flying brick"
Re: brakes help
mounting holes are all the same
thumperslaw
Re: brakes help
AMCQ46 wrote:mounting holes are all the same
cheers dude
K100 "flying brick"
Re: brakes help
the main thing in that table is to get the correct sized master cyl to go with the brakes you fit........you will see they are not all teh same piston sizes and they were uised with different master cyls for that reason.
thumperslaw
Re: brakes help
AMCQ46 wrote:the main thing in that table is to get the correct sized master cyl to go with the brakes you fit........you will see they are not all teh same piston sizes and they were uised with different master cyls for that reason.
Thanks for the info
Good hunting a sp-1 front m/c now
K100 "flying brick"
Re: brakes help
The O.D. of the rotor can be different though.
The only "direct" SP1\SP2 replacement is (I believe) an '06-'07 CBR1000rr
thumperslaw
Re: brakes help
So running 929 forks on sp-1 brakes
Then I might need 1000rr discs
K100 "flying brick"
mik_str
Re: brakes help
Post by mik_str »
if you're running 929 forks, you'll need 929 or 954 rotors (330mm). SPs used 320mm and CBR1000RR used either 310 or 320mm (depending on the years; IIRC, 310s for 04-05, 320 thereafter). Were they radial calipers, you could simply add or remove a shim to compensate, but as they are axial, you with have to use the proper (330mm) rotors or look at getting some adaptors fashioned......
Re: brakes help
Re-reading this thread I'm not sure if some terms have gotten confused.
When you say "brakes" do you mean the calipers? If so, yes they bolt right on.
For some reason I was thinking you were referring to rotors and that is why I gave you the info that I did.
You want to run whatever rotors were stock with the forks you use.... that is the easiest way to get all the bits to line up.
You can mix and match but the reward isn't usually worth the effort with a Honda sport bike USD front end as all the brake set ups work rather well. :thumbup:
mik_str
Re: brakes help
Post by mik_str »
The Nissin axial calipers used on Honda sporbikes of that period are externally identical (same casting). The differences lay in the pistons used (and machining required to make them fit)..... In all instances, they are top quality bits.....
thumperslaw
Re: brakes help
Yes I was asking about different brake calipers fitting
I.e sp-1/954/929
320 discs with 929 brakes and m/c will work then
K100 "flying brick"
mik_str
Re: brakes help
Post by mik_str »
I doubt a 320mm rotor will allow the pads to have full contact; in my mind, it doesn't make much sense in going all out to get great parts then to cut a corner with rotors that won't allow you to get full contact, thereby failing unlock their full potential......
of course, perhaps I should just :silent:
thumperslaw
Re: brakes help
mik_str wrote:I doubt a 320mm rotor will allow the pads to have full contact; in my mind, it doesn't make much sense in going all out to get great parts then to cut a corner with rotors that won't allow you to get full contact, thereby failing unlock their full potential......
Am just finding out what works and what will go
Am not cutting corners just learning
What size rotors would you say then?
K100 "flying brick"
