Project 2
robby_firestorm
Project 2
Post by robby_firestorm »
Hi guys
This is my firestorm
Done:
Viper Race Cans
Double Bubble
To Buy:
Hugger, Undertray, Levers, Indicators, Deuville Top Yoke, Black Renthals
To Do:
Seat Cowl, Tank, Front Fairing, Mudguard, Hugger and undertray Sprayed (Colour not known yet)
Frame, Swingarm, Subframe, Fork Bottoms, Yokes Powder Coated Black
Wheels Powder Coated black with edge of rim matching paint work
Will keep it updated
2000 Firestorm
Re: Project 2
this should be interesting, keep us up to date with lots of pictures.... :thumbup:
Re: Project 2
that's tidy looking.... can I ask why the top yoke change?
robby_firestorm
Re: Project 2
Yes it's for a set of renthals as the deuville yoke has risers.
2000 Firestorm
Re: Project 2
You need to make sure that they use the same IIRC 41mm fork diameter otherwise you will have problems clamping the forks in. It will be a good move if it fits.
robby_firestorm
Re: Project 2
I was going on this old topic that I found.
http://vtr1000.org/phpBB3/viewtopic.php?f=8&t=18325
2000 Firestorm
Re: Project 2
Argh I missed that one, good find. I just checked and it looks like the Deuville does indeed have the same OM Storm fork diameter of 41mm.
http://www.bikez.com/motorcycles/honda_ ... e_2012.php
Looks like the earlier model are 42mm as well.
http://www.deauvilleuk.org/forum/specs.php
And here's a top yolk
http://www.ebay.co.uk/itm/Honda-NT650V- ... 1c19776ab8
The only other issue you may have is the steering stem, hopefully that will fit straight through and then offcourse the fitting of the ignition barrel.
Re: Project 2
To update this thread it has been confirmed that the deuville yoke does not fit so not a straight swap. The stem hole is 10mm too far forward and does not line up.
http://www.vtr1000.org/phpBB3/viewtopic ... 49#p319143
