Noisy Tappets
Woodsy
Noisy Tappets
Post by Woodsy »
Hi,
I've recently bought a 98 model and (according to the previous owner) it had a top end engine rebuild approx 5,000 klms ago (what's that, about 3,000 miles?) due to CCT failure.
It is good and tight and goes like a rocket, however I notice especially when the engine is hot that there is a fair bit of tappet noise, noticeable mainly at idle or low revs.
Is this just in need of the tappet clearances being redone or is it likely to be an indication of CCTs failing (already!).
Cheers, Paul.
Re: Noisy Tappets
Best way to find out is to measure the valve clearances - and at the same time check that the manual CCTs, presumably fitted after the auto CCT failed, are correctly tensioned. If it had auto CCTs refitted after its last episode then strongly recommend you replace them pronto with failsafe alternative, as auto CCTs are binary in operation - They either work or they don't - with potential catastrophic consequences as you're aware.
Stratman
Re: Noisy Tappets
Post by Stratman »
These engines are quite noisy and "rattly" compared to an IL4, if that's what you have been used to. If it is a CCT it won't sound tappetty, but slappety slappety! The only way to find out is to check the clearances, as has been said.
ging500
Re: Noisy Tappets
Post by ging500 »
There is a possibility that it is rattling due to clearances being opened out when the head was rebuilt
Re: Noisy Tappets
Welcome to the club Woodsy, good luck with the bike fella.
Re: Noisy Tappets
Where's ɹǝpun uʍop :confused
Do you know if the tensioners where replaced with either Honda auto tensioners or Manuals.?
Virt
Re: Noisy Tappets
Post by Virt »
cybercarl wrote:Where's ɹǝpun uʍop :confused
The north pole...
popkat
Re: Noisy Tappets
Post by popkat »
Some other area's to look at.
Clutch rattle ?
exhaust gaskets ?
Timing one tooth out ?
Valves usually go tighter with shim type adjustment, so if loose then maybe not set correctly when rebuilt.
