List of required parts...
Moderator: VTRDark
Ckennedy
Post by Ckennedy »
Thinking more on my Euro trip I have realised I need to make some adjustments to the bike and acquire some more bits before I go. In order of urgency which I need:
1: brighter indicators (original storm or after market, front and rear) May have some sorted but pipe up anyway. Would like flush mounts for front
2: Rentect luggage rack. I have the mount bars just no grab rail with luggage rack.
3. Headlight beam adjuster lens.
Could do with them ASAP. Planned trip in 2nd week of Sept.
I did have other things in mind but now I have come to list them I have forgot all of them :lol: :roll: Will add them if I remember.
Thanks in advance
Chris
Re: List of required parts...
Baby wipes is a must
Flatline
Post by Flatline »
Renntec in the ebay thread
Remember you can borrow my rack if needed
There are adjusters for up/down & left/right on the back of the headlight.
Hope you've got spare wine carrying capacity for the return trip Image
And don't bring back any immigrants.
[youtube][/youtube]
Garry Garry ! That's one of my favourite episodes :thumbup:
Ckennedy
Post by Ckennedy »
Do I just need to change it to point left then? or is there more to it?
Hairy biker
Post by Hairy biker »
You need to mask off the 'kick up' on the beam pattern, beam benders are the easy option, you can do it with gaffer tape but it can be a bit of a faf about,you'll be able to see the beam pattern against a wall or garage door, then then you just move the beam bender/gaffer tape around until the kick up disappears and your left with a flatline,its much easier to take it to a testing station and use their beam tester to do it.
Of all the things I've lost I miss my mind the most
Upper left adjuster - Up & Down, Lower right adjuster - Left & right
Ckennedy
Post by Ckennedy »
Think a lens is an easier option. Anyone got one?
:confused 10mm socket , few twizzles & viola beam direction adjusted.
Ckennedy wrote:Think a lens is an easier option. Anyone got one?
It's easy I will show you later .
Just do as Hairy suggested. All that is needed is a triangular shaped bit of gaffa tape or something to block the beam.
http://www.brick-yard.co.uk/vehiclespec ... adlamp.htm
I would juts stick it on so it looks the part. Who gives a sh1t about the beam. If it Blinds the French... well.. wombles um.
http://www.motoring-into-europe.co.uk/faq.html
http://www.halfords.com/webapp/wcs/stor ... yId_165458
lloydie wrote:Baby oil is a must
Yes, and sun tan oil as the cheeks escaping from the speedos on the Riviera beach will go pink in minutes......
