However, before removing the auto on the rear cylinder, I took notice of the amount of play in the chain between the cogs/sprockets, and it was very little, no where near the 7-10mm we work to when setting the manuals up.
Needless to say I had no issues otherwise this thread would be completely different, but it did make me turn the engine over by hand through one full revolution and check I had the marks set up correctly before removing the originals. I therefore conclude that if I used the locking key to fix the position of the auto before removal,( Which I didn't ) then measured the length of the auto and transferred it to the manual before installation, the chain would not have the recommended play in it, 7-10mm. So, either I'm a numpty who is missing something glaringly obvious, or 7-10mm is not necessary, or my camchain is now looser than it was.
