Front Discs
Front Discs
Hi, my bike has just failed it's mot for excessive run out on the front discs
i knew one of them was warped, any suggestions as to were to look for new ones, and what kind to replace them with? thanks.
Re: Front Discs
Honda - David silvers
Re: Front Discs
Thanks mate, thought i may get away with it, i may need a hand putting them on.
Re: Front Discs
You know where I live and the kettle be on :-) .
Ebc make good discs too and so do ap and pfm but my trust is in honda
Re: Front Discs
Thanks for your reply, was talking to the guy from pfm in the isle of man in august, the discs he sells though are a bit expensive but he would give me free pads, not sure about spending that much though, i suppose you have to pay for the best.
Re: Front Discs
Yep the pfm are top money but are great personally I'd love a set on the race bike (I just might get some) if I can get a good deal when it's time .
Re: Front Discs
Been trying to ring for a quote, maybe shut now
Re: Front Discs
Hi
Had same problem myself. 1 disc. Brought a pair off the forum. Tested & fitted all ok.
You are quite welcome to my old discs. I can have them tested & give run out reading.
I work in coventry if pick up from there is easier.
Richard
Richard
Re: Front Discs
Thanks for your offer, i'm waiting for a friend to get back to me, but if they can't help i will get back to you soon as, on my failure certificate it says excessive run out (3.2A1m), if anyone knows what that means?bsabloke wrote:Hi
Richard
Re: Front Discs
According to the workshop manual. Maximum runout 0.3mm or 0.012 in real money.
I had my replacements tested 0.006 & 0.004. Totally changed feel of the brakes. Old discs you could feel it on the lever at light braking & 1 side pads were half thickness of the others. I will get discs tested at work (some trick test equipment). Only any good to you if within tolerance.
Rich
Rich
Re: Front Discs
Ok mate thanks, just let me know if they are ok, i think i did the damage on mine with the disc lock
Re: Front Discs
I warped my discs racing. So it goes. I am sure you all know that cbr 600 f3 discs fit. I have a wheel and good discs I shall sell soon - I believe this is my 50th post!
Re: Front Discs
I'm in the same boat my discs are warped
I personally when it comes to brakes buy new don't play with 2nd hand
Armstrong are not bad as long as u don't do track days or the extreme choice china
Re: Front Discs
Thanks, i took mine to a place in grantham today to get them sorted, he showed me them after and they were fine, i went home and put the wheel back on the bike and went for another mot, guess what? failed again, he showed me on the rollers how bad they were, no better than the first timegabi81 wrote:I'm in the same boat my discs are warped
Re: Front Discs
buying new saves the hassle
and if u think about it its ur life end a day and crap discs=brake failure ....result more cash down the road
so just save and buy new simples
